Results 1 to 8 of 8
09-10-2014, 06:02 PM #1
- Sep 2014
build plate free falls after moving to home axis
I don't know that this is really a problem but a strange behavior for sure. If I tell my 2X to go to home axis, it does, but then the build plate just basically free falls away.
Glad to find this forum after the google group shut down!
09-10-2014, 07:32 PM #2
Is it being driven down by the motor?
It takes quite a bit of force to manually force the plate up or down when not being driven by the motor.
09-10-2014, 07:43 PM #3
- Sep 2014
No. Its just slowly lowers itself free of any motor control. Silently drops. Works fine when I start a print. It's just after going to home axis or after bed leveling
09-11-2014, 04:35 PM #4
Wow, that's really bizarre, never heard of such a thing. Normally the motor, when unpowered, has enough resistance to prevent that from happening. Since all 4 motors are identical, you might try swapping the Z motor with the X (easiest to get to) and see if that fixes it? If the problem goes away, then you know it was the motor. If it doesn't, then it is the drive circuitry on the mighty board.
09-16-2014, 09:58 AM #5
- Sep 2014
This all started sometime after installing aluminum Z arm upgrades. This was the 2nd of 2 printers I installed on, no issues on printer 1. I wonder if it's related. I'll try removing the threaded rod and re-installing. MB support says they've not heard of this.
09-30-2014, 02:39 PM #6
The first thing I wondered, was if you had modified this in anyway. Imo I would think that is somehow what introduced the problem. When the build plate moves down on its own, can you tell if the rod itself is spinning, or does it appear that the threaded rod is stationary? If the rod is stationary than it must be the bearings or bushings. If the rod is spinning then it must either be the motor or the connection point between the motor and the rod.
09-30-2014, 02:43 PM #7
- Sep 2014
Makerbot's reply was that I needed to remove Sailfish and go back to MBI firmware, because Sailfish isn't supported in the 2X.
09-30-2014, 04:26 PM #8
sigh.... what has their customer service turned into? That is false.
This excerpt is taken from Makerbot's own site. http://www.makerbot.com/sailfish/
"The Sailfish firmware described here runs on The Replicator 1, Gen 4, and Gen 3 electronics. For The Replicator 1, single and dual extrusion is supported.
- The Replicator 1: Makerbot MightyBoard rev. E or later electronics with one or two extruders.
- Thing-O-Matics: a Makerbot v2.x motherboard, a Makerbot v3.6 Extruder Controller, Makerbot v3.3 Stepper Drivers, a stepper-based extruder, and an Arduino Mega or Arduino Mega 2560. Other than the extruder, these are all “stock” Thing-O-Matic electronics; i.e., Gen 4 electronics. Stepper-based extruders include the Mk6, Mk6+, Mk7, and Mk8. Other electronics and extruders may or may not work with the Sailfish firmware.
- Cupcakes with Gen 4 electronics: As per the above.
- EXPERIMENTAL – Cupcakes with Gen 3 electronics: A 3G5D Shield or the “Ugly Cable Hack” is required in order to control a stepper-based extruder. Additionally, the remaining complement of Gen 3 electronics: RepRap Motherboard v1.2, Plastruder Extruder Controller, and v2.3 or later stepper drivers."
Mind you sailfish has moved multiple revisions forward than the information found on that page, but I do not believe the creators of sailfish dropped support for the 2X.
I hold by my original request to check the items I mentioned.
New member with print issue
Yesterday, 08:57 AM in Tips, Tricks and Tech Help
