Results 1 to 10 of 25
Thread: Garbled LCD screens
08-22-2014, 12:04 AM #8
To clarify for the interested, the interface involved with at least these display panels consists of six dedicated pins on the Arduino processor. i2c isn't involved. SPI is ran to the panel on at least the RepRapDiscount smart controller, but it is used with the SD card, not the LCD module. The six pins consist of an enable, a register select, and four parallel data lines. Low level operations involved with setting the data lines and toggling the enable and register select pins are accomplished through Arduino LiquidCrystal library functions. Marlin code takes care of higher level stuff like menu structure.
It could be there's more than one thing going on, but static discharge is definitely a way I've seen my display mess up.
