Results 1 to 10 of 25
07-16-2014, 01:11 PM #3
I'm sure the results can vary, but as a datapoint I found an Esteps/mm setting of 877 was way more accurate than the factory default of 841 for my 1.75mm PLA.
Also note that for the i3v printers you want to download the RAMPS code only from the link in the i3v build guide as gmay3 says. Don't follow the i3v RAMPS build video that says to get the code from the link on the RAMPS part of the MakerFarm Build Instructions page. Turns out those files are intended for the i3 and not the i3v. One key difference is that the latter is configured for a RAMPS motherboard type 34 instead of 33. If you're wanting to use a print cooling fan connected to the RAMPS D9 terminals, that difference will keep the fan control from working.Last edited by printbus; 08-07-2014 at 06:38 PM.
