06-19-2014, 01:53 PM #1
Tobeca 2 Portable 3D Printing Releasing on July 15th
For those of you that like travel or move around a lot, there is a new 3D printer coming from Tobeca, a french 3D printer manufacturer. The Tobeca 2 3D printer will be capable of being folded up into a suitcase like box and transported quite easily. Unassembled versions of the printer will be available for 699€ and assembled, it will cost 999€. More specs are below. Read more about this upcoming 3D printer at http://3dprint.com/6641/tobeca-2-3d-printer/
- Size when open - 440 x 414 x 430mm
- Size when closed - 440 x 414 x 175
- Weight - 10Kg
- Power - 220V AC to 12V DC 120W, 82% efficiency
- Electronics - Ramps 1.4
- Firmware - Marlin
- File format accepted - STL, OBJ, GCODE
- Hotend nozzle - 0.4mm
- Print volume - 200x200x250mm
- Moves resolution - 21.7µm (X and Y axis) and 0.39 µm (Z axis)
- Layer height - 0.10mm - 0.30mm
- Print speeds - Up to 200mm/s
- Supported material - PLA, ABS, nylon, soft PLA, and Laywood
Has anyone used the original Tobeca 3D Printer?
06-20-2014, 10:11 AM #2
- Apr 2014
- 16
I don't feel an overwhelming need to transport my 3d printer that often. I guess for people that are constantly moving around this could be a good option.
