Results 1 to 10 of 19
Thread: Crimping vs Soldering
06-18-2014, 02:40 PM #1
- May 2014
- 100
Which is recommended for extending wires such as motors and what not? Crimping or Soldering?
06-18-2014, 02:48 PM #2
- New York
- 66
Motors I would recommend soldering the wires. However for the hot end and I would recommend crimping.
06-18-2014, 02:53 PM #3
- Mar 2014
- Vienna
- 47
For all machines with moving parts is criping not an option!
Printers move quite rapidly and have usually thin wires, especially at the extruder where the termistor is connected. If you have a wiring problem there the result would be a mess - hot end overheated, extruder melted and printer close to burning.
06-18-2014, 03:09 PM #4
- New York
- 66
You simply cannot solder the hot end wires. Soldering will melt again and disconnect. Crimping and then capton would work. The rest should all be soldered.
06-18-2014, 03:21 PM #5
06-18-2014, 03:39 PM #6
06-18-2014, 04:23 PM #7
- Mar 2014
- Vienna
- 47
06-18-2014, 05:10 PM #8
06-18-2014, 06:22 PM #9
- May 2014
- 100
06-19-2014, 03:59 AM #10
- Mar 2014
- Vienna
- 47
After 23 years experience in preparing rallye cars, 15 years experience in electronics and mechatronics - yes I do!
And when we were using crimps (because we needed special connectors) we additionally soldered it, too.
The reason is simple: With crimping litz wires you´ll pressing them together in a certain order. At the first moment everything looks save, can´t move anything. But by the time (e.g. caused by temperature) and also with the movement the litzes beginns to move a bit and rearrange them. This can be the point where they start to get lose.
Unfortunately I had to learn this lesson on a hard way, had such failures in my rally cars which at the end costs me at least one time a win in a national championship. And in my business it costs me money...
