Thread: Hello
06-13-2014, 06:07 PM #1
Hello
Wanted to say hello from N.C. Bought a Creator X off of the bay yesterday, http://www.ebay.com/itm/121359648505
As you can see its new, but damaged. But I believe I can bring it back. I have a 80 watt laser I can make a new front panel.
My first 3d printer and I suppose I could have gotten a much cheaper one, but if this turns out to be ok then I save some bucks. I ended up with 600 in it.
Watching lovethepirk videos I d/led pypy 2.3.1 , replicatorg 0040r23, python 2.7.7, and the makerware bundle 2.4.1.24
Have I missed anything or is there a different version on any of these I should use?
06-13-2014, 09:11 PM #2
- May 2014
- alameda calif
- 18
good for you !!
I got one yesterday brand new showed up with a cracked front panel but works grate!
I love it
I just use rep G so far and with what ever python it said to use
good luck and have fun!Last edited by charlie; 06-13-2014 at 09:14 PM. Reason: forgot some stuff
06-13-2014, 09:14 PM #3
My flashforge turned up with a snapped carriage (the big black plastic thing that holds the tension belt) on the Y axis on the side, don't feel too bad.
06-14-2014, 06:17 AM #4
Checked Fedex and it supposed to get here tuesday. Guy required a indirect signature, which I will be at work, so I was able to print out a form, sign it and stick it on the door.
So, pla or abs? What is the best to start with for a total noob? I am thinking of building a table that puts it higher than countertops or typical tables.
