Thread: ENDER 3d Neo bed leveling
05-04-2024, 03:22 PM #1
- May 2024
Hi, hi have a problem here my bed not leveling, I calibrate the bed and when starts the printing de bed was always derugulated.I already changed the extruder and the motor/rotor , maybe the BL touch?Thanks
05-05-2024, 01:11 AM #2
- May 2020
- 623
You need to explain a bit more about what you mean by deregulated. Perhaps post a photo.
05-05-2024, 09:40 AM #3
Have no ideal what you mean by derugulated.
However I have just had a similar problem after several hours of troubleshooting I have learned that the SD card was causing the problem.
I tested the SD card on my PC reformatted many times tested perfect on my PC and the Problem persisted until I replaced the SD card with a different card.
I was not allowed to use the Auto Bed leveling feature without an error, when I tried to manually level the bed all seemed to be well until loading G-Code for a print.
Then the nozzle would never be in correct position for filament to stick to the bed.
After grabbing an SD card from my second 3D Printer did I discover that it worked perfectly, an again was capable of leveling the Bed.
My suggestion is to try a different SD card, as the one you are using may not function correctly on your 3D Printer.
It needed still have the SD card could make a video to show everything, problems and solutionLast edited by Roberts_Clif; 05-05-2024 at 12:05 PM.
