Thread: Issues with first print
01-09-2024, 05:21 AM #2
- Nov 2022
- 18
You will need to add supports to print that object.After slicing, use the Slice Preview and step thru the layers (L/R arrow keys) from the build plate up.You will see you are trying to print into thin air (best seen from the side view).Just add supports and it will print just fine.Enjoy!
