09-14-2023, 01:05 PM #1
- Sep 2023
Filament not coming out when printing
Hello!
I have a Flash Forge Adventurer 3 Lite printer. It appears that there is no filament jam because when I load it, the filament comes out properly. The problem is when I try to print. The printer parts move as expected but the filament won´t come out from the nozzle. I would appreciate any help. Thanks a lot in advance.
09-18-2023, 07:54 AM #2
- Nov 2022
- 18
What slicer are you printing from; FlashPrint5?
Does the feeder click when attempting to print (trying to push filament that won't move)?
Many things could cause that problem, from a loose wire connection, erroneous slicer setting, bad stl file, etc.
Things you can try:
Unplug the printer for a minute and plug it back in; reset the electronics.
Check your nozzle temp when printing and make sure it's not shutting off.
Try printing a known good .stl file to make sure it's not just a bad file you're trying to print.
Good luck, hope you get it working.
09-19-2023, 04:40 PM #3
- Sep 2023
Kickstarter campaing LEGENDARY...
Today, 08:02 AM in Free Self Promotion
