06-09-2023, 10:57 AM #1
- Jun 2023
- Long Beach, IN
New to 3D Printing / Qidi X-Plus II for nylon
Hi folks, happy to join this great resource of knowledge. I have a need to make some parts out of nylon and have acquired an X-Plus II 3D printer, Sovol SH01 filament dryer, and a spool of Overature Nylon Filament
The first part I want to make is from a SolidWorks .sldprt file, volume is ~ 2.6 cubic inches (43 cc). Any suggestions for a first timer to be successful with this venture?
I have zero experience with this, what is my first step after setting up the machine? I have an extensive background of injection molded nylon applications.Last edited by Paul Fithian; 06-09-2023 at 11:03 AM.
06-19-2023, 01:18 PM #2
- May 2020
- 634
You'll need file of whatever you want to print that is in a format that your slicer understands, save it as STL file in Solidworks.
Then slice it and export the generated G-code as a file.
Save that to an SD card or USB stick and print from that in your printer.
06-21-2023, 08:10 AM #3
- Jun 2023
- Long Beach, IN
Thanks Bikeracer2020, I do have the STL file. I plan to set the machine up in a few days after completion of the room it's going in.
