05-01-2023, 06:48 PM #1
- Nov 2021
Printing Problem - FlashForge 3D Creator Max
I just obtained an Creator Max and after getting it setup I did a test print of benchy and it was almost perfect so I decided to try another one and this one started off great. Meaning the bottom layers were near perfection but the layers after that were a complete disaster, at which point I halted the print. I am wondering what would cause this, I am including pictures for reference.
05-22-2023, 07:00 AM #2
- Nov 2022
- 18
Did you ever get this fixed?
I see over 1100 reads, but no replies.
A little more info would help like what material, temp, and slicer used (and did you check and see if supports are required).
You can rule out a mechanical issue by printing something simple like a cube stretched in the z axis a little taller than where your print is messing up.
If that prints ok, then you can most likely rule out any mechanical issues, and look into slicer settings.
