Thread: Roller Wheel Issue?
04-08-2023, 01:44 PM #1
- Jan 2023
- 6
Roller Wheel Issue?
When I received my Ender 3 S1 and first assembled it I noticed the X and Y motion had what felt like a dead spot in the rollers or the aluminum guide itself. So I adjusted the roller tension which was indeed too tight. The dead spot was now only slightly noticeable, and over time seemed to diminish.
Lately printing in spiral/vase mode I notice at a certain elevation the layers are off like something randomly shifted. I'm printing at a relatively slow 50mm/s, .2mm layer. I notice this defect to varying degrees on similar prints.
I know its tough to quantify but how smooth should the X?Y axis move? Does the rolling resistance need to be perfectly constant or is some deviation OK?
04-13-2023, 06:13 PM #2
- Jan 2023
- 36
HIit should be pretty smooth if all things are going well. So clearly there is something going wrong. I would maybe try replacing the rollers if you think that is the issue. you could also try tightening the lead screw but other than that i am out of options. Hope this help good luck trying to find the solution
