Thread: Ender 5 S1 Cooling Issues
12-23-2022, 05:25 PM #1
- Dec 2022
So I recently purchased an Ender 5 S1, the newest addition to the Ender 5 lineup, and the printer has been working great until about 3 prints ago. Essentially what happened was I set the flowrate too high on Cura, as it had been lightly underextruding, and it ended up overextruding... seriously overextruding...The print nozzle was rubbing ridges in the print, which was a flat circle, and was causing so much friction that the print popped off of the print bed and moved to the left, however the printer did not start stringing, it began shifting each layer to the right anywhere between a millimeter and 1.5 centimeters. Ever since that print, the right cooling nozzle, I am not sure if it is related, however it may be. The Sprite extruder has 1 fan that blows through a duct and out of 2 nozzles, and had been working perfectly. To highlight this effect, I printed a pin support challenge, and one side is perfectly good, an extremely high quality 3D print, while the other is sagging, the layers are not attached and looks horrible.Any ideas as to how I can fix this?
New member with print issue
