08-03-2022, 11:23 AM #1
- Aug 2022
Gaps between outer and inner wall layers, in a pattern
My print is getting little gaps between the outer and inner wall layers. It happens every time, and looks identical when I print the part multiple times. It happens before the seam that runs down the side of a print.
I just got new PLA from an new manufacture, which I thought was the problem, but I did a PLA temp tower in CURA and it looks flawless, bridges and walls are absolutely perfect. So I don't know if its the cylindrical shape, or if the model files are messed up.
I attached pictures of what I'm talking about. you can see it happens before the seam. The big piece I have printed once, but the little cone I have printed 3 times, and all three times it has come out identical the holes and defects always in the same spots and patterns
I have a Voxelab Aquila. I use fusion 360 to make the models, and use ultimaker to slice them.Last edited by NoahNorman; 08-03-2022 at 01:40 PM. Reason: adding additional information
