07-20-2021, 07:06 AM #1
- Jul 2021
What’s the problem with this print?
Hi,I am trying to identify the problem. The print looks quite good, except the occasional horizontal lines. Is that due to over extrusion? I am using simplify3D slicer, printed on creakily CR-10.Empty shell, the wall line count (outline shells) is 1.Any input would be greatly appreciated!
07-20-2021, 08:46 AM #2
07-20-2021, 09:17 AM #3
- Jul 2021
07-20-2021, 10:19 AM #4
- Jul 2021
I figured it out. That's where the layers start and stop. The best way to avoid it is to adjust the setting in the slider software to start the new layer closest to a certain coordinate.
For example in the print above, I set the starting point on X-axis to be middle of the bed, and y-axis to be middle / closer to the bottom. This way, all the layers start inside the model, at the bottom, and the outside perimeter looks great.Last edited by RedAlert; 07-20-2021 at 10:46 AM.
07-20-2021, 07:54 PM #5
- Jul 2021
- 26
Where the nozzle starts at stop is called the seam. As you said, the best way to avoid it is too set where you start and stop layers in your slicer. In cura, there are options such as wipe distance, which can also hide the seam better, I am not sure what these are called on Simplify 3D.
Printing time- Is this right?
