Results 1 to 8 of 8
Thread: Spring mount for bass drum pedal
05-13-2014, 09:36 AM #1
- May 2014
I was told you people might like this!
The original part had a really sloppy design and eventually broke so I decided to make a new, better one. Designed in Solid Edge, cold printed cheap china PLA with 0.2 mm layer height, 0.8 density. Works like a charm!
https://imgur.com/a/5rY4d#19GsPgF
2014-03-21 20.52.54.jpg2014-03-21 18.31.22.jpgLast edited by oskarbjo; 05-13-2014 at 09:40 AM.
05-13-2014, 01:15 PM #2
- Mar 2014
- 20
This is a very clever idea. Looks pretty good. How is it holding up so far?
05-13-2014, 02:55 PM #3
- May 2014
Thanks! Has worked just fine so far. You see the original solution was to have the threads inside the actual part, which was made from a way too porous material, so they eventually broke. Now I can tighten it just as hard as I want and IF I'd break the threads again I could just replace the screw and/or nut
05-14-2014, 04:22 PM #4
- May 2014
- Houston
- 53
Nice! How much use does it get?
05-15-2014, 06:52 PM #5
- May 2014
Not too much I'm afraid! I have a bunch of other pedals as well
05-21-2014, 03:53 PM #6
- May 2014
- Houston
- 53
Are you planning on 3d printing any other musical parts?
05-22-2014, 06:17 PM #7
- May 2014
Well, I've been thinking about making a guitar capo. Would have to figure out how to make it fit to different guitar models though! If I make one I'll make sure to post it to thingiverse
05-23-2014, 02:49 PM #8
- May 2014
- Houston
- 53
That would be awesome.
