Results 11 to 17 of 17
03-14-2021, 05:40 PM #11
- Mar 2021
- 63
Thanks a bunch, I'll take a close look at those settings in the morning. And maybe make a new config. Is that what I should do in the absence of an Ender 3 V2 option?
Did you see my screenshots OK?
03-14-2021, 06:28 PM #12
I saw your pics ok. I made the same box for my deep well mm sockets a while ago using a LQ config.
03-16-2021, 11:54 AM #13
there are no practical differences between the ender versions.
the mk2 uses a cheaper and less solid frame and - I believe - cheaper, but newer, control board.
But they've done nothing to improve speed - so you'll still need to keep it fairly slow.
03-16-2021, 12:36 PM #14
- Mar 2021
- 63
Thanks, will experiment along those lines.OT question: when replying to posts the only option I see is ‘reply with quote’.Is that the case for all, implying that quote has to be deleted if not needed?
03-18-2021, 03:36 PM #15
just use the quick reply box.
You won't have the moderator options - but you should have the rest.
03-27-2021, 11:36 AM #16
- Mar 2021
- 6
After right clicking ; click on multiple model set to get that.
03-29-2021, 01:10 PM #17
- Mar 2021
- dg khan
Yes you can do it
