Results 1 to 10 of 89
05-09-2014, 10:56 PM #24
- South Australia
- 50
This is how it bis set now, but I have to lift for homing in the sliced code, it wont lift if I just use a G28.
// these are the offsets to the probe relative to the extruder tip (Hotend - Probe)
#define X_PROBE_OFFSET_FROM_EXTRUDER 0 //-25
#define Y_PROBE_OFFSET_FROM_EXTRUDER 0 //-29
#define Z_PROBE_OFFSET_FROM_EXTRUDER -4.4// -1.8 -9 -12.35
#define Z_RAISE_BEFORE_HOMING 10 // (in mm) Raise Z before homing (G28) for Probe Clearance.
// Be sure you have this distance over your Z_MAX_POS in case
#define XY_TRAVEL_SPEED 8000 // X and Y axis travel speed between probes, in mm/min
#define Z_RAISE_BEFORE_PROBING 10 //How much the extruder will be raised before traveling to the first probing point.
#define Z_RAISE_BETWEEN_PROBINGS 5 //How much the extruder will be raised when traveling from between next probing points
