01-26-2021, 06:41 AM #1
- Jan 2021
$Bounty$ Cura Profile for Ender 3 V2 with 0.8mm Nozzle
Edit: This issue has a $20 bounty for resolving the issues in printing at a 0.6mm layer height.
I am trying to print very large items that do not require a lot of detail on the Z-axis. Because of this, I have an Ender 3 V2 (4.2.2) running Marlin 2.0 setup with a 0.8mm nozzle. I have seen a lot of information that printing up to 0.6mm heights should be fine with the nozzle however in testing some more challenging pieces of a larger print, I have discovered that I get some pretty unsightly issues at anything over 0.4mm layer height.
The main issues I have are.
1. Anything over 0.4mm layer height produces blobs on most of the Z seam.
2. Anything over 0.4mm layer height produces inward bowing of the walls at tight corners.
3. Even with a 0.4mm layer height, there is still some blobs on the Z seam at the tops and bottom of print walls.
I have attached both a Cura profile of the 0.56mm layer height I have been trying to get work and the Cura project file of the example. If you have experience with this, please let me know what I am doing wrong.
Thank you!
IMG_8851.jpgIMG_8848.jpgLast edited by Shape&Raise; 01-26-2021 at 02:54 PM.
