Results 1 to 10 of 757
05-07-2014, 10:41 AM #8
Yes, that should be possible. The logic should map over. But I don't think very many people are using Repetier. Is that assumption not correct?
Well... I'm not sure if I followed everything, but it sounds like that acrylic plate is not very flat. Is that what you mean by 'uneven spots' ? As far as only doing 3 spots on a Delta printer, that should be just a matter of turning on the right options and setting where the 3 measurements will be taken on the bed. I would encourage you to do more than 3 spots, but if your bed is pretty flat and level, you may get good results with that.
