Results 31 to 37 of 37
Thread: Looking for large 3D printer
09-24-2020, 11:44 AM #31
- Jan 2016
- 326
Check the screw under the X-Axis gantry. The screw should be in the hole near the edge of the gantry so that it trips the limit switch hidden in the carriage. Which material did you use? Try higher extruder and/or head bed temperature.
09-24-2020, 02:05 PM #32
for simplify 3d you need to set the origin at x=0 and y=0
09-28-2020, 08:01 PM #33
- Jan 2016
- 326
The new relay board came today but it's the same board as the old one. They sent me some wires and a new switch for the front panel. I'm not sure if I should replace the parts now or wait.
09-29-2020, 11:49 AM #34
well it will be the same part. just hopefully not faulty :-)
10-04-2020, 10:46 AM #35
- Oct 2020
- Peopoly Phenom — Large Resin 3D printer.
- Dremel Digilab 3D45 — Reliable Large 3D Printer.
- Raise3D Pro2 & Pro2 Plus — XXL 3D Printer!
- BCN3D Sigmax R19 — Large Workhorse 3D Printer.
- Ultimaker S5.
- BigRep Studio — Gigantic 3D Printer!
- Concept Laser X Line 2000R — Gargantuan 3D Printer for metal. geforce pour pc
10-05-2020, 05:38 AM #36
02-06-2021, 04:00 PM #37
- Jan 2016
- 326
I need new build plate and nozzles for my Sainsmart Coreception. The glass build plate's coating is damaged and I don't know what size of nozzles I need. Any suggestions?
