Results 1 to 10 of 10
04-29-2014, 02:17 AM #5
- Honolulu, HI
- 199
Your z-axis screw can cause ribbing if it is not straight. We've discussed this at length at printrbottalk and threw lots of numbers and calculations around. In the end it all boiled down to how straight the lead screw is and how it is attached to the stepper. I'd recommend you use 0.2mm as a starting layer height and not worry about your screw pitch and diameter.
