Results 1 to 10 of 27
Thread: Need Help choosing a 3D Printer
04-22-2020, 06:20 AM #9
See now I was being good and not just saying: 'for christ's sake GET SOMETHING ELSE !'
Here's the reasons they are so bad. At this point I think my keyboard can pretty much type this by itself :-)
The original prusa I3 design has:
1) dual z axis stepper motors - for even and smooth raising and lowering of the large and heavy z/x-gantry.
2) the print bed has dual guide rails at either side of the bed - this gives you a stable bed that will stay level and can move fast and smoothly.
3) A direct drive extruder - this gives you faster, nore precise printing and makes using flexible filaments a breeze.
Creality decided to throw all those out the window and make a machine with an uneven bed, jerky z axis and a bowden extruder (only necessary because they removed the right side z-motor) that makes printing any filament a random shot in the dark.
Add to this creality's famous lack of customer support and their cost cutting excesses where quality is concerned and you have one of the worst printer designs on the planet.
The ender 3 is responsible for MORE 'problem with...' threads on this forum than ALL OTHER PRINTERS IN THE WORLD added together.
So no, I would not recommend you buy one :-)
Those are the fundamental reasons.
So why do you think it's a decent machine - it's an interesting question.
And the reason is simple: marketing.
Creality spend more money on marketing than on components.
pretty much all the positive reviews on youtube have been paid for. Even if it's just being paid with a 'free' printer and the promise of more printers to review in the future - if you post a good review.
And yes I have been contacted by creality to do a review and they very quickly went away when I said I'd do an honest review :-)
So because the ender 3 sells so many units and it's very cheap to make. Lots of other manufacturers decided to adopt the creality design.
So most current i3's on the market have all the worst bits of the i3 and few if any of the good aspects.
There are a couple around I can recommend.
The sovol 01 has both dual z axis motors and a direct drive extruder.
Okay it's still got the central bed rail - but they have used 20x40 extrusion so it' a bit more stable than most and bed levelling doesn't seem to be an issue.
Sovol small, young company who currently still have a customer focussed approach. Also a very good facebook group.
The weird thing is that the very cheapest i3 ever sold - actually HAS/HAD all three key prusa design aspects.
I know, I've got one - it cost £85 and would blow an ender 3 off the planet. Okay the frame is made of plywood and you need to bolt the whole thing to a rigid surface to stop frame movement between the y and z/x axis.
But it's a great little machine. And it can genuinely be called a Prusa I3 - well as far as mechanical design goes - NOT for any other reason.
The motherboard is the cheapest ramps board around and the extruder doesn't even have spring grip drive wheels (weirdly it's an amazing little extruder that can push pla through fast enough to do 200mm/s at 0.3mm layer height and flexible filament at 40mm/s).
But because the mechanics are sound - it will outperfom any creality design around.
If you could still buy them for sensible money I'd recommend one, it does need tinkering with but nowhere near as much as a non-prusa i3 design. And bolting thing to plywood is actually easier than with aluminium extrusion.
Oh yeah and the screen sucks :-)
You can still buy them in the uk: https://www.ebay.co.uk/itm/3D-printe...QAAOSw9MRd~IBj
And from normal ebay in the states a swell: https://www.ebay.com/itm/From-UK-CTC...wAAOSwOJhejJWZ
I've spent about £15 on mine - but it desperately needs a better screen and a board that you can improve the firmware on.
So my advice would be to buy one of those and spend $100 on: a solid base, good motherboard, touch screen and - maybe - a better extruder. Oh and a sheet of pei for the bed :-)
It's a perfect for tinkering while being cheaper and better than the ender design.
ACTUALLY this one has already got better board and screen and proper z-screw connectors AND aspring loaded extruder - bolt it to a sheet of plywood and you're done :-)(mine came with some dodgy silicon tubing to conect the stepper to the z screws): https://www.ebay.com/itm/Geeetech-Pr....c100005.m1851Last edited by curious aardvark; 04-22-2020 at 06:56 AM.
