03-18-2020, 05:12 AM #3
- Mar 2020
- 6
If you're using SketchUp, you could make two cubes against eachother and then subtract the model out of the middle of the cubes (half from each cube). Then just pull the two cubes apart and print them separately.
You'd also have to put some holes and pegs and such in there to make sure they stay together when you do the mold, but it should work.
