Thread: Beginner Resin printer help
02-24-2020, 11:35 PM #1
- Feb 2020
Hello,
I recently purchased the Anycubic Photon resin printer to mostly print tabletop miniatures. When the print finished, the arms and the spear they were holding were completely flat. Is there a setting in the slicing software I am missing that'll fix this issue? I have included pictures of them below.
Thanks in advance!
02-25-2020, 05:44 AM #2
not used a resin slicer - do you get a print previw ? if so check it's not the model that's the problem rather than the printer.
02-25-2020, 04:54 PM #3
- Aug 2015
- 256
You need to use supports! Those areas look as if they were unsupported, which means they would not lift off the bed until the print reached the arm-pit area, which is why they look flat. Since they didn't peel off the bed, every slice of the spear printed on top of itself.
My suggestion: use Chitubox, and watch this guys excellent videos on how to do supports:https://www.youtube.com/watch?v=rR-0tbBbyXk&t=657s
Ender 3v2 poor printing quality
10-28-2024, 09:08 AM in Tips, Tricks and Tech Help
