10-15-2019, 07:38 AM #4
Setting M851 - XYZ Probe Offset in te Cura Startup G-Code area.
In My version of Firmware can set the Z-Offset from the LCD display and save the settings.
Do not know what firmware you are using
Though you should be able to do a M503 this will tell you the current settings, I am using a Raspberry pi with OctoPrint installed.
As my 3D Printer is in a different room and not connected to my computer. Below is a sample of part of my M503.
You will note that the third line down is M851 and demotes my settings.
Wanted to make a foot Note Here.
When I upgraded to Marlin 2 some time Ago had to forgo the use of M503 as not using it saved me enough memory to enable me to use the Marlin 2 versions.Last edited by Roberts_Clif; 12-02-2020 at 06:50 PM.
