Results 1 to 10 of 13
06-12-2019, 04:42 AM #5
- Jun 2019
- 8
Hello folks,
Just sharing my experience.
I have MakerGear M2 printer with E3D V6 and Titan Extruder Modifcation. I needed to print 600 parts from TPE filament. I had hard time to manage it to print even at 10mm/s always jams, wraps around hob gear e.t.c. I found a nice solution here https://www.thingiverse.com/thing:2600963. Its solves everything. I printed from here only top part which prevent to slide filament on the side. I started with 30mm/s for test and its doing fine no problems at all. I bump it slowly till 50mm/s and this is maximum how I can get with flexible filament which I think is pretty impressive. I finished my order for all 600 parts with only two fails. I can post a settings from simplify 3d and also firmware setting from Marlin. If somebody interested.
Hope its helps somebody!Last edited by gagat_studio; 06-12-2019 at 06:03 AM.
