Thread: Need help with printing quality
06-11-2019, 01:09 PM #1
- Jul 2017
Hi everyone! I am having this imperfections in my prints and im not sure what it is, ive been trying to solve it for quite a while now and i have not been succesful. I would appreciate the help. Thanks!
I am printing at 210 ?C, 40 mm/s printing speed, outer wall 20 mm/s, retraction enabled, 0.2 mm quality.
06-11-2019, 05:33 PM #2
It appears it could under-extruded
What material are you trying to 3D Print.
06-11-2019, 05:40 PM #3
- Jul 2017
Pla 1.75 mm
06-11-2019, 07:56 PM #4
Do you have an all metal hot-end or do you have a Teflon tube in the throat.
If you have a Teflon tube you may want to disassemble the hot-end to see if the Teflon tube has deformed.
06-11-2019, 08:06 PM #5
- Jul 2017
its all metal, but if its not a software calibration or firmware issue i would guess theres something wrong with the extuder
06-12-2019, 04:52 AM #6
I have very little to go on, you have provide the forum with only of a photo showing under-extrusion.
Then Stated "PLA 1.75mm"
If you would provide more information, it could make it much easier to help you solve the problem.
Is it a new build , what 3D Printer, What firmware are you using , was it factory flashed or do you have the Configuration files.
06-15-2019, 10:17 PM #7
I would defiantly lean towards an extruder/extrusion issue as well.
