Results 11 to 20 of 26
12-06-2018, 12:16 AM #11
- Dec 2018
- USA
List of some of the most popular D3 modeling software are Sketchup, LibreCAD, SelfCAD, AutoCAD
12-07-2018, 01:25 PM #12
the old cura was quite good. But then they completely redesigned it and since then it's been really horrible.
The last user friendly version was: 15.04.6
here's a list of al releases: https://ultimaker.com/en/products/ul...-software/list
12-18-2018, 07:31 AM #13
12-18-2018, 07:37 AM #14
You can look my 3d print model the website below.
https://www.3d2v.com/n.design
02-05-2019, 05:50 AM #15
- Dec 2018
- 62
I will suggest you some of these best 3D modeling softwares - LibreCAD, TinkerCAD, Blender and SketchUp etc.
02-07-2019, 07:23 AM #16
If you can afford a license, Solidworks. The next best thing is Rhinoceros, it is great with meshes as well.
For a nice free and quick solution use Sculptris.
I use Blender to boolean away shapes, say create a flat bottom. That is about what I know in Blender, steep learning curve indeed.
02-07-2019, 11:28 PM #17
- Dec 2018
- 62
@Ralphzoontjens, I agree with you, Sculptris is also a good option and the best thing is that it is free. Most of the educational institutes use Sculptris for educational and enrichment purposes.
05-18-2019, 02:16 AM #18
You should have a look at www.rocket3f.com/ (just add dotts)
05-19-2019, 04:05 PM #19
Added the dots :-)
Looks interesting, and the basic version is Free !
Which as everyone knows, is my favourite cost of anything :-)
I need to make 3d faces on spheres, and doing it on openscad is a real pita. So let's see if i can use this rocket thing instead :-)
well first snag - it doesn't save or export as .stl
About the only thing I can see that openscad will import is .dxf
have to try that instead.Last edited by curious aardvark; 05-19-2019 at 04:30 PM.
05-20-2019, 12:07 AM #20
You could export it to obj and then open it in 3D Builder
www(DOT)microsoft(DOT)com/en-us/p/3d-builder/9wzdncrfj3t6?activetab=pivotverviewtab
Her is a little about it: www(DOT)windowscentral(DOT)com/how-use-3d-builder-windows-10
Its easy to use and you can export to stl from there, and its free.
