Results 21 to 25 of 25
04-15-2014, 10:33 PM #21Bambu P1S/AMS
04-17-2014, 04:27 PM #22
Ok ran the marinated ABS last night and it appears to have some filament out-gassing on the finished edges. Then ran the same filament @ room humidity of 55% and you can see the difference. So conclusion do not soak your ABS in H2O but I dont think high humidity will bother it much. Ill post back in the summer when humidity hits in the 90% range..
04-17-2014, 05:02 PM #23
Ah, marinated ABS. Let me get my fork and knife out and tie my 3d printed bib around my neck....
Yes, I figured it might not go too well but you don't know until you test it. That's the whole tenant of science.
Great test. It's good to see a good photo of what severe "out-gassing" looks like. If for nothing else, the test gives us a good image of that so when it happens we'll know.
I'm a little confused about what you are saying about the same filament at 55% and 90% humidity. What are you doing there?
What I need to do (and I will when I get some time) is leave a piece of filament out for 1-day, 1-week and 1-month and then print the same object against fresh and humidity-free filament. Then examine them closely and see if I can tell which is which. In a perfect world, you would not be able to. That test will take some time as I'd need to take the "month" piece out now and then wait 3-weeks to take out the next piece....etc. I will do this one day soon.
Explain the next step was confusing and report back with the results. Nice work...Bambu P1S/AMS
04-17-2014, 05:12 PM #24
What I mean about 50% that is my current room humidity and in the summer it will be 90% so Ill post back when the humidity is high to see if I get any out gassing.
04-17-2014, 05:51 PM #25
Ok, I gotcha. That makes sense. You are just saying that right now, with your filament always out, you don't have problems in a 50% humidity environment. If that's the case, that's good to know. I have AC so I don't really ever get much more than 50%. So, I maybe should not worry about it too much. I've printed on a roll for 3 or 4 days but then I always put it away. I haven't had any moisture problems that I know of. I need to do the test I mentioned earlier. Maybe I'll stop and do that tonight.
Bambu P1S/AMS
My 3D Norn Emissary print
09-13-2024, 02:28 AM in 3D Printing Gallery
