Results 11 to 12 of 12
11-12-2018, 09:35 AM #11
- Nov 2018
As was already said, you are looking at the very low end of the cost/quality spectrum. You should expect to make some compromises, and in some cases modifications. Also, take with a grain of salt those that say that you must modify a printer to optimize it. This is a hobby for most people and as such they are often looking for ways to modify the printer whether is needs it or not. Think of it like car enthusiasts, a person might spend $1000 on a spoiler for their Honda Civic, while they will likely see no real performance gains at normal speeds. Or in a more extreme case, they might put a snorkel onto their truck and extend the breather tubes for the differential. All the while knowing they will likely never drive their truck into a body of water, or even off-road in many cases. Why do they do it? Mostly because it looks cool. Is it better to have truck that can drive through 3 feet of water? Sure, but if you never need it, what is the point?
I would argue this point, you should get a kit and build it yourself.
1: It will get you to understand all the components and how they work.
2: The printer will break eventually. When it does, you'll be prepared to troubleshoot and fix it.
I recommend Folger Technology kits, they are all aluminum frame, have good instructions and a large user base. Cost starts about $300
12-16-2018, 10:37 PM #12
- Dec 2018
- USA
Where did you get started?
