08-22-2018, 03:59 PM #4
As the Filament is pressed through the extruder it is suppose to stick to the bed.
If the filament is loosely affixed at some point the tension can pull the filament causing it to become a warped shaped circle.
Then on multiple rotations some of the filament may hold in place forming the circle that was to be printed.
This would also account for the warp in the model not to lay flat on the bed surface.
So the Answer is Yes.
Below is a toy truck printed on Pressure Sensitive Carpet Glue on Paper Tape On the Aluminum Bed.
Could not get to print on anything was about to give up. Now I can print on anything just prefer the Vinyl Transfer Paper Tape with PLA.
Toy Truck No/Supports
https://youtu.be/QhWuMxtKV6M
Will Vinyl Transfer Paper Tape release my Print
https://youtu.be/Y5ut1OtMSp0Last edited by Roberts_Clif; 08-23-2018 at 04:41 PM.
