Thread: Thin filament line
05-08-2018, 08:06 AM #1
- Mar 2017
- 9
Thin filament line
Hi
So I have a 1.mm nozzle I want to print something big with heavy lines..
The filament comes out very thin like a thin line with tiny balls more like a pearl necklace.
Attached is a picture with my setting someone told me would work good..
Anyone know what is happening?
Thanks for any help..
05-08-2018, 08:38 AM #2
First I would reduce the PLA temp to around 200-210C. 245C for PLA seems to me an extremely high temperature.
My PLA prints occur between 192-202C though with so many variations of PLA you may need a higher temp than I use.
Second I would increase the Layer height to .4 and maybe reduce the print speed by 20-30%.
Top and bottom layer thickness do not need be any thicker than twice the layer height, a layer thickness of 10 times seems a bit much
05-08-2018, 08:43 AM #3
- Mar 2017
- 9
I will try that.
On my filament roll it has the temp at 245 and bed 60.
thank you
05-08-2018, 10:15 AM #4
This seems unusual to me so I did some research. (Are you sure it is not some other type filament)
Under Problems With PLA In the link below
http://www.soliforum.com/topic/7889/...-a-solidoodle/
You may try printing a Temp Tower
http://forums.designfutures.club/t/t...la-hips-etc/84
05-08-2018, 11:09 AM #5
- Mar 2017
- 9
You are right about that..
I read the label wrong, it is celsius.
Thank you..
05-09-2018, 05:54 AM #6
yes we know it's celsius - but are you sure it's pla ?
Unusual for pla to be printed above 230.
The only pla i have that prints best 230-240 is the new ULtra with nano-diamonds. And that's noticeably harder and denser than normal pla.
RC is bang on for everything else. :-)
