Results 11 to 15 of 15
Thread: Newbie needs advice
01-09-2018, 07:24 PM #11
- Jul 2017
- 184
Not exactly, the reason a bigger printer should be slower is because it has a bigger, heavier gantry. This means lower accelerations, which means slower prints, particularly on prints with lots of small details. This is especially true with mendel (prusa) style printers which have particularly high moving mass because of moving the print bed. I was talking about different sized printers, not printers of the same make and model, and my point is they shouldn't have the same settings for different sized printers.
You could set the accelerations/jerk/speed on a larger printer the same as a smaller printer, and they would print in more or less the same time, but you shouldn't. A larger printer with more moving mass should have lower accelerations/jerk/speed to avoid ringing artifacts. Nothing to do with the clock of the microcontroller.
01-10-2018, 11:25 AM #12
- Jan 2018
Trakyan, that makes sence.Thanks for the clear explanation.
01-11-2018, 03:57 PM #13
- Jan 2018
Yeah. As the guy said, a bigger printer is slower mainly due to the heavier gantry. But it is a lot more detailed!
01-11-2018, 08:01 PM #14
- Jul 2017
- 184
It's not more detailed. It has to be slowed down to stop it from /losing/ detail. The heavy gantry causes larger acceleration/deceleration forces which are what cause a lot of printing artifacts. On top of that a longer spanning gantry will be less rigid. You can lower speed and acceleration to compensate for the higher mass (more mass --> more acceleration/deceleration forces) and lower rigidity. But this is just to maintain print quality, not to make it better than a smaller printer.
How detailed your print turns out is a function of your resolution and your accuracy/rigidity. All printers use basically the same motors, pulleys and belts so resolution is more or less the same. Accuracy and rigidity are related, a rigid machine means you can move more accurately (since the machine wont be wobbling, flopping and flexing around). Larger printers are less rigid usually because they are using parts intended for a smaller printer. You can make due with a less rigid printer by going slowing down and lowering the forces it has to deal with, but this won't give you better results, just 'not worse' ones.
What big printers are good for though is large, single piece models. That being said, people usually post process models quite a bit by sanding/painting and gluing a few smaller parts together would add very little to the time spent in post process.
02-12-2018, 05:21 PM #15
- Feb 2018
The Prusia I3 that you identified is a great choice for a first printer. From what you write above all you need is a printer with a build volume large enough to make the largest part of you model. Also note that a model of a star ship can but cut in two, each part printed and the parts glued together. Just place the glue lines in places where they will not show.
Also for model building yo likely will "finish" the printed parts with sand paper and likely paint.
About the fact that you are modifying and printing Star Trek models has no bearing on what printer you get. All the ""work" will be done on the computer using some modeling software of 3D CAD, Blender, Solid Works or whatever. The printing part is rather dull after you get the setting tiled in you can sleep while the printer works. What you do is work on a computer and whatever software you choose is independent of the choice of printer.
There are MANY I3 printers. You can buy a really nice one for $400 that is ready to go or build a kit for $150. In the end you will modify and upgrade either one.
