Thread: Newbie needs advice
01-08-2018, 03:32 PM #1
- Jul 2017
- 184
You have some misconceptions about Simplify 3D, what it is and what it does. It is a slicer that converts your 3D model into instructions for your printer, that's about it. It can move and arrange objects on your print bed for a job but that's as far as it goes. It does not make models.
1) That is not the job of a slicer (what S3D is), it's the job of a constraint solver, a lot of 3D modeling programs have this. FreeCAD, fusion 360, solvespace and more. What exactly is taking a long time here? It's a fairly short and sweet task in any modeler that can do it.
1) a) again, the job of a constraint solver. Nothing to do with a slicer.
2)If you just want to combine pre existing models, meshmixer is probably the simplest software. If you want to make models like props or characters from movies and games, a parametric modeler like fusion 360 or freeCAD won't work as well since they're suited for engineering shapes, not organic ones. The issue here is that organic modelers that you'll want for these types of objects don't usually have constraint solvers (for your gears and such), I think blender does. Another thing is organic modelers aren't suited to making engineering parts like mechanisms and gears and stuff. You'd probably need to learn two programs for your two separate needs.
3)Things are not nearly as simple as what you're describing ('delete the beard') unless someone made the beard as a separate part, and when using an organic modeler people rarely (never?) do this on purpose if at all. The beard is part of the head, and you'd need to remove it yourself, and then sculpt the details in to replace the beard. Think of it like a clay figure, you cant just 'delete' a beard on a clay figure, you need to cut it off then re sculpt what is underneath. Same goes for everything else you're asking about in #3.
4)No, it can't.
Your complaint seems to be that the software you have is taking 'a lot' of work to do 'simple' things. The thing is, you'll get better and faster at doing things with practice, and the things you're expecting to do are not simple. For #1 it's fairly simple in a powerful CAD program. For #2 cutting and combining models is relatively simple, but creating a part of the design yourself is not. For #3 these things just aren't simple, everything here requires you to sculpt the model yourself, at which point there isn't much point in using someone else's model.
