Results 1 to 10 of 10
01-05-2018, 06:54 PM #3
- Feb 2017
- 79
I do not know if cura addressed this I was just stating I'm aware there is a newer version of cura but it presents many problems and many are not solved. I cannot use the current version of cura for a few reasons one of which I mentioned as to try to avoid being advised to "use the newest cura". With that said, what other methods would you recommend? How about what slicers? I'd be willing to try others just to see if they handle this the same way. I'm just trying to understand why cura would not support this when it's set to support all. I was hoping there was something it was missing (Or I was missing) to make it determine this was not an overhang and that it did not need to be supported.
Thanks
Dave
New member with print issue
