11-27-2017, 04:08 PM #1
3D printer took a bad fall - where can I get frame parts?
The front and rear corner plastic supports for the X and Y axis chrome shafts split.
The right side (facing machine) Y axis rod is bent....need a new one.
The bearings are damaged it appears because the rods move a bit in the mounts on the X and Y axis.
Anywhere to buy these?
11-27-2017, 09:35 PM #2
11-28-2017, 05:18 AM #3
the plastic supports I'd say make - but if that's your only printer, then you can't.
The rods should be available from any 3d printer parts supplier, or ebay.
Likewise the bearings.
Probably worth contacting flashforge for the plastic parts.
