Thread: Mod for Prusa that detects jams?
11-18-2017, 12:23 PM #3
- Nov 2017
- 17
The MK3 uses a laser sensor to track filament movement. If filament stops moving, its a problem. Unfortunately if the item unsticks from the bed, that won't help much.
I own an MK2S printer, and its a good piece of machinery, but I notice they brag about some innovations, but they often aren't the full solution. For example, yes it does have mesh bed leveling, not that manual leveling is that hard, but what it DOESN'T have is auto Z-height adjustment, and that is tricky for many and a pain.
If you search for mishaps of the Prusa, jammed filament isn't a real problem that happens much, an item breaking off the bed IS a big problem, and usually it happens hours after the print is started.
New member with print issue
