Results 1 to 9 of 9
10-24-2017, 05:10 AM #9
Have you used the same filament in the other extruder as well? Otherwise you are not ruling out issues with the filament.
Some cheap filaments start to bead up above certain temperatures. Rather than a continuous stream they become stringy with the occassional bead.
Also it can be containing too much water - look if the extrudate contains small bubbles or steam develops.
