Thread: eBay filament??
09-25-2017, 02:33 PM #1
- Aug 2017
- 45
eBay filament??
I just got some clear filament and put it in an airtight container with a device that tells the humidity.It read 60 percent off the gitgo ,is it any good.It was packed with 1 dessicant pack.I have put 8 of the small dessicant packs in there with it.
09-25-2017, 02:43 PM #2
I have been printing with E-Bay filament for over a year with no problems.
all package are vacuum sealed impossible to have 60 percent humidity.
09-25-2017, 03:09 PM #3
- Aug 2017
- 45
Do you think it will print alright?
09-25-2017, 06:50 PM #4
I do not think you will have any problems unless the filament has bubbles where is has adsorbed moisture. then you will have to dry the filament.
https://printspace.freshdesk.com/sup...water-moisture
I keep my filament in a large plastic container with every desiccant type package I have ever found.
And never open the vacuum sealed filament packages until needed.
09-25-2017, 10:35 PM #5
- Aug 2017
- 45
I just bought a big pack of the small dessicant filters this month.On the filament that was messed up I noticed that the filament bag on this order was not vacuum packed .It was packed in a bag you could move the bag around.Do you think the filament bag had gotten punctured?It still had a dessicant pack inside.
