Results 1 to 10 of 474
09-24-2017, 10:34 AM #11
- Jul 2017
- 193
I started making a few low layer count prints and they are coming out very nice. I started a Benchy today and around layer 30, (.2 mm height ) the bed had an some slight movement / shifting. the glass to aluminum bed is not moving, but the spring adjustment mechanism is. What would cause that. How tight is your bed on the springs, and do you guys have any modes to secure it better. Seems like a problem.
I have attached a photo of the x and y springs. The seem like they are fairly far inserted.
Also, my cura engine settings are
print speed:50
outer perimiter speed :45
infill speed: 80
I do need to connect my nozzle fan...
The bed is level according to the output from a G29 command.
11:33:15.580 : Z-probe:59.96 X:-66.00 Y:-38.00
11:33:20.881 : Z-probe:59.91 X:66.00 Y:-38.00
11:33:26.066 : Z-probe:60.01 X:0.00 Y:66.00
11:33:28.072 : Z-probe average height:59.96
How accurate is the stock z-probe. Should I use the extra z-stop switch
I also know that my glass is somewhat wavy near the edges. number40fan replaced his glass. What is a good source of new glass?
Any help is appreciated
