Thread: HICTOP Prussa I3 Parts
09-23-2017, 11:56 AM #1
- Sep 2017
- 6
I just purchased the 3DP-11-ATL and one of the acrylic mounts (11.00YKLXPJ01.BLACK.003) is broken. I emailed the company and went online to try and find a replacement part but am not seeing this part exactly. I do see some upgraded parts that I could print, but before I can print anything I need to have this part so I can print. Any suggestions?
09-23-2017, 04:20 PM #2
Two Pair of vise grips, need to hold Smooth rod the long enough for just printing One mount.
Clamp the smooth rod then Clamp the vise grip to the Frame with the Other. should hold for the duration of a single print.
P.S. Duct tape super glue the Pieces together only printing one piece.
Y-Axis
y_end_bracket_left[1].stl
y_end_bracket_right[1].stl
Z-Axis Top
top_bracket_left_standard_shape[1].stl
top_bracket_right_standard_shape[1].stl
These keep the Smooth rod from moving on the Stepper motor.
bothsideRodfixhalfheight.stlLast edited by Roberts_Clif; 09-23-2017 at 04:48 PM.
09-23-2017, 05:20 PM #3
- Sep 2017
- 6
I will give this a try. Thanks for the help.
