Results 11 to 17 of 17
Thread: Model to big-need to split it
08-14-2017, 02:58 PM #11
- Aug 2017
- 8
Hi-
Not sure why my profile has me listed as a 'student' b/c I'm much older than that. Actually I'm a teacher Must be some default profile setting when I created the acct. Anyhow...
Looking at a new design for my base using the 'spinner fidget' toy. Is it possible to create an enlarged version of a spinner toy via a 3D printer? Say I wanted to scale it by 3 or 4 times the toy size.
Any suggestions on a simple way to create an enlarged version for printing purposes?
08-14-2017, 03:05 PM #12
- 885
you're a student based on the number of posted messages.
Scaling a previously created STL file is pretty easy. I use OpenSCAD, Meshmixer and some Fusion 360 and Blender for my modeling projects. All are free. Pick one or more, use The Google to look for "scale STL in OpenSCAD" or your selected program and you'll have plenty of solutions at hand. You can scale uniformly in all three directions, or only two at first, then make it thicker as needed. Much flexibility awaits you.
08-14-2017, 03:19 PM #13
- Aug 2017
- 8
Aha. No wonder I couldnt find the setting to change it!
Does that mean I should be able to find a public .stl file for a spinner?
08-15-2017, 10:55 AM #14
Hi,
Please send me the stl file then I will send you the quote.
We have 3 sla machines 24inx24inx16in and 3 different materials.
Regards
Bogdan
bogdan@customprototypes.ca
14167080857
08-15-2017, 11:12 AM #15
- Aug 2017
- 8
Hi-
Thanks for all the info and offers to print...I'm re-working the design after another thought.
10-01-2017, 01:49 PM #16
- Oct 2017
- Canal Winchester, Ohio
Chappie99,
I can fit those bad boys on my Union Tech RSPro600 in one-piece. No Problem! Might also be able to produce them out of nylon on my HP machine. Let me know if you need help with this still. My email is 3DPrint@AerosportModeling.com
10-02-2017, 05:40 AM #17
the designations are based on the number of posts a person has in the forum - pretty standard for forums. :-)
how large a spinner are you after ?
And check out www.thingiverse.com for many spinner designs.
