Results 1 to 10 of 474
07-27-2017, 11:44 AM #1
hanging spool below extruder is awkward as you've got to move the the wrapped extruders wires - well wrapped mine :-)
Plus where my printer sits it just wouldn't fit.
As long as the cables aren't in the way - can't see why not though.
bendy cable snake looking quite good, Interesting to see how well it builds out the angled square. Probably shouldn't have gone for 0.3mm layer height.
Probably should have added extra process just for that part.
But I'm always in a hurry lol
Ah well we'll see.
You can't see the grooves that well in the picture, but they run along both sides and the top - hopefully it'll articulate at those points.
I've got a 50cm 3mm aluminium disc that's used in my portable balearic slinging target.
Sized a 350 (actually 370 as you need screw holes to mount it) disc against that.
Holy crap it's big ! lol
With a 350mm build plate you can actually fit a 100mm x 340 rectangle Or a 245x245 cube.
That should be big enough, Figure I'll need some kind of run out of filament alarm thing as wellLast edited by curious aardvark; 07-27-2017 at 11:57 AM.
