Results 1 to 10 of 474
07-12-2017, 04:26 PM #11
wow 6mm aluminium bed !
why ? That's massive overkill, plus would take all damn day to heat up.
3mm should be fine, 4 at a push, what am i missing ?
Plus if I'm using a pc psu for the bed, why not use it for the board as well.
Easy enough to use a 500watt.
Also why 1.8m vertical struts ? Current struts are 680mm. so to extend print height to 600mm I would only need 980mm verticals - you'd use 1metre lengths, just to save messing about chopping little bits off. If you go any taller you'll need to switch to 3mm filament and life's too short to have to buy two different filament thicknesses.
You're talking about a 1.5 metre build height. That wouldn't even fit in my workshop, unless I left it on the floor lol
The struts I'd have to buy, but any plate would be free.
These guys are clients of mine - and I like to keep the favour ratio in my favour :-)
http://www.jskaluminium.co.uk/engineering.htmlLast edited by curious aardvark; 07-12-2017 at 04:55 PM.
