Results 1 to 8 of 8
02-24-2014, 05:48 AM #1
- Feb 2014
- 11
Solidworks.... Any Good for Design?
Is anyone using Solidworks for designing their 3D prints? How is it? Is it any good or is there another software that you would recommend?
02-24-2014, 10:53 AM #2
Its great for logical designs, But not that great for something like a Yoda head for example,
But its great to make other things like, a fan holder and such, Logical things.
02-24-2014, 11:25 AM #3
- Feb 2014
- Waco Tx
Solidworks is a great piece of software. It is hard to make organic shapes like the Dr has mentioned. BUT Solidworks is a very powerful parametric modeling software and if you are looking to get your feet wet it is a great place to start.
I use PTC Creo 2.0 and it is similar to SW in that is is your typical parametric modeling software but it does have a feature where you can take a blob of clay basically and mold it and make very organic shapes quickly and easily. If you have access to SW then it will be great for what you are probably needing. If you are looking to buy some software and drop major cash then look at Creo.
03-01-2014, 07:05 AM #4
SolidWorks is the best out there right now. Most community colleges also have SolidWorks fundamentals/advanced classes if you want to learn more.(or jus use youtube.) Another good one that I have heard a lot of goo things about is Creo, chec kit out (both are spendy though if your not a college student).
07-10-2017, 01:07 PM #5
- Jun 2017
- 28
Solidworks is great if you have money to spend on it, or don't feel bad about pirating it (no judgement from me, especially if you're using it for side projects and not to make money). I've used it for over a decade for making mechanical designs. I will echo the sentiment that it isn't very good for artistic projects, but it is extremely powerful for more analytic mechanical designs.
I've been messing around in Autodesk's Fusion 360 for a little while as well recently. It has a pretty powerful free form side to it, along with the parametric modeler. Price is my main motivation for using it though. You can get a free hobbyist license as long as you make less than $100k, and if you don't fit that requirement, it's only about $360 a year.
Onshape is another option. There's a free plan for it as well, but you can't keep your designs private under that plan. It is extremely close to Solidworks, and it's no surprise because former Solidworks people started it.
07-24-2017, 01:22 PM #6
- Jul 2017
When I was going to college I instructed a course on how to use solidworks. Now that I'm done with college I use FREECAD since I can't afford solidworks. SolidWorks is a much better program, but I wouldn't use it unless I thought I could get some sort of a return on investment. If I was an engineer I'd probably use it. Solidworks has pretty good FEA built into it too.
I personally would like to turn a profit from some of the models I make, so I don't want to be encumbered by licensing. That's one reason I choose FreeCAD and one reason not to make anything in a pirated version of commercial software.
09-04-2017, 09:16 AM #7
If you are looking at complex organic modeling, Rhino is a better option.
But if your work is more engineering/manufacturing oriented, Solidworks is still the software package of choice.
Also for vehicle design you can get pretty advanced with it.
11-26-2017, 10:24 PM #8
- Nov 2017
Like I said, they serve the exact same function
AceWorldTrading
