Results 1 to 8 of 8
06-15-2017, 08:39 AM #1
- Jun 2017
Help with finshing 3D printed props
Hi all,
I have spent the past year getting to know my 3D printer and getting all the settings dialled in and getting the best quality prints I can straight off the bed. Now I am starting my first 3D printed prop and this is where I need to help and advise (I hope this thread is in the correct group)
I have wet and dry sandpaper of varying grits and this is a good start to smooth out the print lines. However, I need to do some filling. Some are large areas and some are small indents that need filling. I see in the most of the videos people use Bondo Spot Putty. However in the UK, this is really expensive to get hold of, some people are charging up to £43 P&P!!! can anyone in the UK suggest a product that's not too expensive to use for filling large areas and small areas.
Thanks
06-15-2017, 09:11 AM #2
- Aug 2015
- 241
I found a website that is called Youtube, that has some information on that subject
you might find more.
https://www.youtube.com/results?search_query=fiishing+3d+prints
06-15-2017, 09:34 AM #3
- Jun 2017
Hey, there is this thing called sarcasm it's super useful!!!
Just hoping that the reply from this is the normal standard of useless reply on this site
06-15-2017, 09:38 AM #4
if you mean epoxy putty - poundland sells it. not so expensive :-)
The other thing you might try is ordinary gap filler. Big tubes from all good discount and pound shops :-)
Sandable, paintable and shrink and stretchable as well - so it says: http://www.poundland.co.uk/tommy-wal...t-filler-310ml
They sell actual squeezable tubes in poundstretcher as well - but they don't have a searchable website.
And all good hardware stores will also sell it.
Got to be worth a try :-)Last edited by curious aardvark; 06-15-2017 at 09:46 AM.
06-15-2017, 10:02 AM #5
- Jun 2017
Thanks, curious aardvark I have some test pieces to work with that I have printed out. I will give this a try.
06-15-2017, 04:58 PM #6
Prop as in cinema? Or Prop as in Boat propeller?
For my RC yachts I use this nasty green stuff. I forget the name, i get it from the hobby shop, but it's been around a while, and it's got some chemical that's a skin irritant, but it works like bondo, pretty cheap, and is specifically made for plastics. Sands down easily and paints very well. I guess it'd work pretty well for stage props too I guess. Or you could be making a prop prop.
After a bit of googling, it turns out it's called "green Putty" by MMD.
06-18-2017, 08:58 PM #7
- Jun 2017
- 28
Has anybody had any experience using this?
https://www.smooth-on.com/product-line/xtc-3d/
I've been meaning to give it a try, but I haven't had a need for a real smooth finish on anything yet.
06-19-2017, 05:19 PM #8
I haven't tried that particular product, but the smooth-on products I have tried are wonderful, if expensive.
Today, 02:07 PM in General 3D Printing Discussion
