06-12-2017, 12:38 PM #1
- Jun 2017
- California
Want to put a 2 wire connector on my 40 mm fan.
I have little to no experience with wiring. i'm trying to put a connector on my 40 mm fan so that maintenance and such is easier. Dose anyone know what connectors i need? in case it matters my printer is a Qidi tech 1
Thanks everyone. its all done now up and running!Last edited by CharlieBot; 06-15-2017 at 03:51 PM. Reason: Problem solved
06-12-2017, 04:10 PM #2
- Jun 2017
- 38
As long as you get both ends to the connector, I don't see why it would matter which one you install.
06-13-2017, 01:25 PM #3
spade connectors are pretty straight forward.
This sort of thing: https://www.amazon.com/Hilitchi-100p...ade+connectors
Your local buck store should stock them, or any budget hardware store.
My cooling fans are just wires twisted together and taped. But I have fitted an on off switch to them both.
