03-18-2014, 05:48 PM #1
- Mar 2014
- 14
Is there any way to keep MakerWare from printing a line before printing?
Is there any way Makerware can be adjusted not to print a line in front of the Makerbot table every time, before printing a part?
I manually removed this line from G code and it didn't change anything.
Over time this wastes more filament.
Thank you.
03-28-2014, 03:18 PM #2
- Mar 2014
I don't believe that line is the in the GCODE, rather a firmware function. It's meant to clean/wipe the nozzle and spit out leftover material. Most decent to HQ printers do it. It really doesn't waste much IMO.
03-28-2014, 05:35 PM #3
There is no way to remove this line, without it you run the risk of starting your print with burnt plastic, or no plastic.
Just do what I do, save all your plastic scraps. That way, when they finally make a plastic reclaimer, you have something to use it with.
