04-23-2017, 06:47 AM #1
- Mar 2017
- Scotland
CTC prusa i3 pro B Auto bed leveling
Hi all has any one ever fitted this printer with a probe like this LJC18A3-H-Z/BX 1-10mm Capacitance Proximity Sensor Switch NPN NO DC 6-36V 300mA
if you have can you please help a novice who is stuck i have fitted the sensor to the printer and i have wired it but on the signal wire i get 0 volts that can't be correct I thought i would need at least 5 volts i just don't know what i have done wrong.
05-11-2017, 05:18 AM #2
- Apr 2016
- 120
So long as you have the polarity correct, then yes I agree, you should see a voltage when at the correct height. Are you using the resistor method to connect to the Z stop and have you connected it correctly?
New member with print issue
